Applies to: Self-hosted Mattermost Server (all supported versions) running server-side plugins, on systemd or Docker.
Symptoms: The mattermost process grows in resident memory over time, and a plugin is suspected as the cause.
🛑 Problem
Server-side plugins run as separate child processes of the main mattermost process, so a plugin that retains memory shows growth in its own process rather than in the server's. When memory growth appears in the main process instead, the plugin is not necessarily the source, and log lines attributed to a plugin do not establish where the memory is held. Without a heap profile the growth cannot be assigned to any component, and if the host exhausts available RAM and swap, the kernel's out-of-memory killer can select a process anywhere on the system, which can take down unrelated services alongside Mattermost.
Symptoms
- Resident memory of the
mattermostprocess climbs steadily and does not return to baseline after periods of low activity. - Plugin log lines all report
callervalues in the server's plugin API rather than in the plugin, because the server relays every plugin log message. This says nothing about which component holds memory. - Plugin subprocesses showing low, stable memory in
psrules the plugin's own process out, but does not by itself implicate the plugin in the main process's growth. - Growth well beyond the node's expected working set, relative to the published reference architecture for its user count, indicates abnormal retention rather than normal usage.
🔍 Diagnostic Steps
These steps attribute the growth to a specific component and cap the damage in the meantime. They do not stop a leak; a confirmed leak needs a fix in the component that owns it.
Capture a Support Packet While Memory Is Still Growing
Generate the packet before the process is restarted or killed, while memory is still elevated. The packet includes <node-id>/heap.prof, <node-id>/cpu.prof, and goroutine dumps per node, which is the only evidence that attributes memory to a component.
mmctl system supportpacket -o /var/tmp/mm_support_packet_growth.zip
Read the profile with pprof, sorted by retained bytes:
go tool pprof -top -sample_index=inuse_space heap.prof go tool pprof -web -sample_index=inuse_space heap.prof
⚠️ Important: A packet taken after a restart is of no diagnostic use for this purpose. The heap profile reflects the state at capture time, so the capture has to happen during the growth.
Sample the Plugin Subprocesses Over Time with childmem
childmem samples the child processes of a named parent process on a timer and writes the readings to CSV, which makes growth in a specific plugin visible across a run.
go build -o childmem . ./childmem -pname mattermost -includeParent -output /var/tmp/child_mem.csv
Leave it running for the duration of the suspected leak, then compare each plugin's memory column over time in the CSV. Growth confined to one plugin's row points at that plugin; growth across the parent row with flat plugin rows points elsewhere, and the heap profile is then the only way forward.
Correlate Against Plugin Hook Metrics with Prometheus and Grafana
With Prometheus and Grafana deployed, compare memory growth against plugin hook activity. Query the rate, not the raw counter:
rate(mattermost_plugin_hook_time_count{plugin_id="<plugin-id>"}[5m])
process_resident_memory_bytes
go_memstats_alloc_bytes⚠️ Important:
mattermost_plugin_hook_time_countis a cumulative counter that resets only when the process restarts. Reading its absolute value as a per-hour rate overstates the load by however long the process has been running.
⚠️ Important: Connecting to the
/metricsendpoint over HTTP, which Prometheus scrapes, requires a Mattermost Enterprise license.
Cap Memory for the systemd Unit
Setting a limit on the unit converts a host-wide out-of-memory event into one confined to Mattermost, so other services on the node survive. Add MemoryMax to the [Service] section of /etc/systemd/system/mattermost.service, sized to leave headroom for the OS and any co-located services:
[Unit] Description=Mattermost After=network.target [Service] Type=notify ExecStart=/opt/mattermost/bin/mattermost TimeoutStartSec=3600 KillMode=mixed Restart=always RestartSec=10 WorkingDirectory=/opt/mattermost User=mattermost Group=mattermost LimitNOFILE=49152 MemoryMax=<value, e.g. 6G> [Install] WantedBy=multi-user.target
Reload the unit definition and restart the service:
sudo systemctl daemon-reload sudo systemctl restart mattermost
Restart=always with RestartSec=10 brings the server back automatically when the limit is reached. Confirm the limit is active:
systemctl show mattermost -p MemoryMax -p MemoryCurrent
⚠️ Important: Plugin subprocesses share the server's cgroup, so the limit applies to the unit as a whole and cannot isolate a single plugin. Reaching it terminates the whole Mattermost service, including plugins.
Cap Memory for a Docker Deployment
The official Compose file already sets a mem_limit on the mattermost service. Adjust it to match the host, keeping it below total host RAM:
mattermost:
image: mattermost/${MATTERMOST_IMAGE}:${MATTERMOST_IMAGE_TAG}
restart: ${RESTART_POLICY}
mem_limit: <value, e.g. 6G>Apply it by recreating the container:
docker compose up -d mattermost
Verify the limit and watch usage:
docker inspect -f '{{.HostConfig.Memory}}' mattermost
docker stats mattermost⚠️ Important:
docker statsreports the container total, not per-process figures. To see individual plugin processes, run childmem or the equivalent sampling inside the container withdocker exec.
Contact Mattermost Support
If the heap profile does not explain the growth, or it points at a plugin, open a support case and attach the packet captured during growth along with the memory and hook-rate graphs for the window preceding it.
