Applies to: Mattermost Server v11.7.6 and earlier; High Availability cluster deployments.
Symptoms: Disabling and re-enabling the Plugin Subsystem in System Console wipes all plugin configurations in an HA cluster.
đŸ›‘ Problem
In HA clusters, nodes can have partially inconsistent plugin config views due to async synchronization. When the System Console sends a config PATCH with an incomplete plugin subset, the server overwrites the full plugin config with partial data, deleting configs for plugins not in the payload. Specific to HA environments; single-node deployments unaffected.
✅ Solution
Upgrade to v11.7.7 or later (fix backported to v11.7 ESR; also in v11.10).
v11.7.7 changelog: "Fixed an issue with plugin configuration loss on High Availability nodes with incomplete plugin sync."
