Applies to: Mattermost Server with data retention enabled; on-disk or network storage (including AWS EFS); any server version.
Symptoms: The data retention job fails with a permission denied error when deleting files. After fixing permissions, AWS EFS Console shows no change in storage size.
Confirmation status: Pending confirmation — engineer provided the fix but customer did not explicitly confirm resolution.
🛑 Problem
The Mattermost data retention job runs as the Mattermost process user (UID 2000 in containerized deployments). If directories under the data path were created with different ownership (e.g., from a migration or volume restore), the process cannot delete them.
Symptoms
error: doJob: Data retention job failed., DoFilesOnDisk: Unable to remove the directory. unable to remove the directory <YYYYMMDD>: open /mattermost/data/<YYYYMMDD>/...: permission denied
- Data retention job shows "Failed" in Policy Log.
- Directories in
/mattermost/data/are owned by a different user. - After a successful job, AWS EFS Console may still show the same storage size (display lag — not a real issue).
✅ Solution
Step 1: Fix directory ownership
ls -la /mattermost/data/ chown -R 2000:2000 /mattermost/data/<affected_directory>
Replace 2000:2000 with the actual UID:GID of your Mattermost process user.
Step 2: Re-run the data retention job
System Console > Compliance > Data Retention Policies > Run Deletion Job Now. Confirm status shows "Success."
Step 3: Verify storage was freed
df -h /mattermost/data
Important: AWS EFS Console metrics may lag. Use
df -hon the server for authoritative storage usage. Directories not named inYYYYMMDDformat are never deleted by the data retention job.
