Applies to: Mattermost Server (self-hosted, all currently supported versions)
Symptoms: You are unsure which GIPHY API key to use or what to enter in the GIPHY API Key setting.
🛑 Problem
Mattermost uses GIPHY to power the built-in GIF picker. When configuring the GIF integration, administrators are often uncertain about the GIPHY API Key field: whether a key is required, what value to enter, and what happens if the field is left blank.
There is no obligation to supply a key. The field is optional, and the behavior differs depending on whether you provide your own key or leave it empty.
âś… Solution
You have two valid choices for the GIPHY API Key setting. Both result in a working GIF picker.
Option 1: Use Your Own GIPHY API Key
Enter a key from your own GIPHY application. Navigate to System Console > Integrations > GIF (GIPHY), set Enable GIF Picker to true, and enter your key in the GIPHY API Key field. The underlying config key is:
ServiceSettings.GiphySdkKey
To set it via config.json instead:
"ServiceSettings": {
"EnableGifPicker": true,
"GiphySdkKey": "your-giphy-api-key"
}Obtain a key by creating an app in the GIPHY Developer Dashboard.
⚠️ Important: When you use your own key, all GIF usage counts against your GIPHY application. You are responsible for monitoring that application's rate limits, quotas, and any content-rating or terms-of-service constraints GIPHY applies to it. If your key hits its limit or is revoked, the GIF picker stops working for your users.
Option 2: Leave the Field Blank to Use the Built-in Mattermost Key
Clear the GIPHY API Key field (leave it empty) and save. When the value is blank, the server falls back to a default GIPHY key that Mattermost owns and compiles into the server binary at build time (via the MM_GIPHY_SDK_KEY build flag). No key value is required for GIFs to function; this is the default, out-of-the-box behavior.
⚠️ Important: With this option you rely on the Mattermost-owned key and do not manage a GIPHY application yourself. This is the simplest choice if you do not have a reason to track or control GIPHY usage on your own account.
Additional Resources
For more information, see:
