Agents Page Shows Upgrade Wall on Professional License (Agents Plugin v2.1.0–v2.2.0)
Applies to: Mattermost Server v11.7.x · Agents Plugin v2.1.0–v2.2.0 · Professional license
Problem
On a Professional license, Agents Plugin v2.1.0–v2.2.0 incorrectly replaces the Agents management page with a "Self-Service Agents" upgrade wall. This is a confirmed frontend regression — existing agents are intact in the database and the backend API is unaffected. The fix is in v2.4.0+, which requires Mattermost Server v11.9.0 or later.
Solution
Option 1 — Upgrade server to v11.9.0+ and install Agents Plugin v2.4.1 (Recommended)
  1. Upgrade Mattermost Server to v11.9.0 or later: server upgrade guide.
  2. In System Console > Plugins > Plugin Management, upload and enable Agents Plugin v2.4.1.
  3. Navigate to /plug/mattermost-ai/agents and confirm the agent list is accessible.
Option 2 — Downgrade Agents Plugin to v2.0.5 (if running on ESR v11.7.x or if a server upgrade is not immediately possible)
  1. In System Console > Plugins > Plugin Management, disable the current Agents plugin.
  2. Upload and enable Agents Plugin v2.0.5.
  3. Navigate to /plug/mattermost-ai/agents and confirm the agent list is visible.
⚠️ Downgrading removes features added in v2.1.x–v2.2.x. Validate in staging and take a database backup before downgrading in production.
Was this article helpful?
0 out of 0 found this helpful
0 comments
