Overview
Mattermost has introduced updates to the Free offerings in v11. For a full overview of these changes, please review the resources below:
If you need to migrate from Enterprise or Entry Edition to the Team Edition, follow the instructions below based on your installation type.
Important: Migrating from Enterprise/Entry Edition to Team Edition will remove all Enterprise-only features.
Before You Begin
Please ensure you create backups before starting the migration.
- Your database
- Your configuration files
Migrate Based on Your Installation Type
Docker Installations
To migrate to the Team Edition, update your Docker configuration to use the Team Edition image.
You can modify your docker-compose.yml or Docker run command to reference:
mattermost/mattermost-team-edition
Tarball Installations
For tarball installations, follow the standard upgrade process documented here:
Note: When downloading the package, choose the Team Edition tarball instead of the Enterprise Edition tarball.
