Applies to: Mattermost v7.7 and later
Symptoms: pgloader migration fails with "Threads.teamid" column not found error
🛑 Problem
During a MySQL to PostgreSQL migration using pgloader, the migration fails with an error indicating that the Threads.teamid column cannot be found in the target "mattermost"."threads" table.
This issue typically occurs after migrating from MariaDB to MySQL, where the Mattermost v7.7 migration may not have applied correctly, resulting in an incorrect database schema.
Symptoms
Users experiencing this issue will see:
ERROR: column "Threads.teamid" not found in target table "mattermost"."threads"
Additional symptoms:
- pgloader migration process fails to complete
- Threads table contains incorrect
TeamIDcolumn instead ofThreadTeamID - Schema inconsistency detected after MariaDB to MySQL migration
âś… Solution
Before attempting the PostgreSQL migration, correct the MySQL/MariaDB schema by removing the incorrect column.
Root Cause
The Threads table contains an incorrect column (TeamID) that should not exist in the schema. The correct column name should be ThreadTeamID.
This schema inconsistency may result from:
- Incomplete or incorrect migration from MariaDB to MySQL
- Custom build modifications
- Schema corruption from a previous migration attempt
Step 1: Back up your database
Create a backup of your database before making schema changes:
mysqldump -u [username] -p [database_name] > backup_before_fix.sql
Step 2: Remove the incorrect column
ALTER TABLE Threads DROP COLUMN TeamID;
Step 3: Verify the schema
DESCRIBE Threads;
Ensure that ThreadTeamID exists and TeamID does not.
Step 4: Proceed with PostgreSQL migration
Once the schema is corrected, retry the pgloader migration to PostgreSQL.
⚠️ Important: Always create a complete database backup before modifying schema or performing migrations. Test the migration process in a non-production environment first.
Additional Resources
For more information, see:
