Applies to: Mattermost Server v11.x and later
Symptoms: Server fails to start after upgrading from 10.x to 11.x with configuration error about hidden archived channels
🛑 Problem
Mattermost 11.x removed support for hiding archived channels. If your configuration has this setting enabled from a previous version, the upgrade will fail and the server will not start.
Symptoms
Users experiencing this issue will see the following error in their logs:
Error: failed to load configuration: failed to create store: unable to load on store creation: invalid config: Config.IsValid: Hiding archived channels is no longer supported. Make these channels private and remove members instead.
âś… Solution
To resolve this issue and allow the server to start, choose one of the following options to modify your configuration file.
Option 1: Set Configuration Value to True
Edit your config.json file and set the value to true:
"TeamSettings": {
"ExperimentalViewArchivedChannels": true
}Then restart the Mattermost server.
Option 2: Remove Configuration Setting
Edit your config.json file and delete the ExperimentalViewArchivedChannels setting entirely, then restart the Mattermost server.
⚠️ Important: After resolving the startup issue, consider migrating away from hidden archived channels. Make affected channels private and remove members to control access instead.
Config-in-Database Environments
If your Mattermost configuration is stored in the database rather than in config.json, the file-based solutions above do not apply. Because this issue prevents the server from starting, the System Console and mmctl are also unavailable.
âś… Solution: Environment Variable Override
Set the following environment variable before starting the server:
MM_TEAMSETTINGS_EXPERIMENTALVIEWARCHIVEDCHANNELS=trueWhere to set it depends on how Mattermost is deployed:
systemd: Add it to your
mattermost.environmentfile. -
Docker / Docker Compose: Add it to the
environment:block or.envfile. -
Kubernetes (Helm): Add it to
envVarMaporextraEnvVarsinvalues.yaml.
Additional Resources
For more information, see:
