Problem
When running a bulk index job against AWS OpenSearch, only a single day of data is indexed even though the job reports success. Historical data remains missing from search results. Running Bulk Index does not backfill historical content.
AWS OpenSearch blocks wildcard destructive operations that the Mattermost purge process relies on. Attempts to manually purge or delete indices do not resolve the issue.
Symptoms
Users experiencing this issue will see:
Additional symptoms include:
- Successful bulk index job messages but only one day of data indexed
- Purge Indexes command failing silently or partially completing
- AWS OpenSearch restrictions preventing action.destructive_requires_name=false from being set
Solution
Follow these steps to resolve the indexing issue and backfill historical data:
Add Ignored Purge Indexes
Navigate to System Console → Environment → Elasticsearch → Indexes to skip while purging and add the following configuration:
.plugins-*,.kibana*,.opendistro*,.opensearch*,.ql-*,.tasks*
This ensures Mattermost skips protected AWS system indices during purge operations.
Purge and Reindex
Perform the following actions in order:
- Disable Elasticsearch indexing
- Re-enable Elasticsearch indexing
- Run Purge Indexes
- Run Index Now
Remove Old Indexing Jobs
Old indexing jobs should be deleted from the database. First, verify existing jobs:
SELECT Id, Type, Data, CreateAt, Status FROM Jobs WHERE Type = 'elasticsearch_post_indexing' ORDER BY CreateAt DESC;
Delete the old indexing jobs:
DELETE FROM Jobs WHERE Type = 'elasticsearch_post_indexing';
Verify the deletion:
SELECT COUNT(*) FROM Jobs WHERE Type = 'elasticsearch_post_indexing';
After deleting the old jobs, trigger Bulk Indexing again, and historical data should begin to populate.
Check OpenSearch Templates (Optional)
If needed, verify index templates using the following command:
curl -X GET <OPENSEARCH_URL>/_index_template -u USER:PASS
