Problem
Organizations running High Availability Mattermost deployments need to upgrade their servers without experiencing downtime or service interruptions for users.
For these organizations requirements may or may not include:
- Need to upgrade Mattermost version without service downtime
- Users must remain connected during upgrade process
- High availability deployment with multiple nodes and load balancer
- Configuration stored in database (not file-based config.json)
Solution
Use the rolling upgrade approach to upgrade each Mattermost node individually while maintaining service availability. The load balancer automatically handles traffic routing based on service health.
Prerequisites
- High Availability Mattermost deployment with multiple server nodes
- Load balancer configured to distribute traffic across nodes
- Mattermost version 8.1 or later
Supported Upgrade Paths
Non-ESR Upgrades: Adjacent minor version upgrades (e.g., 9.1 → 9.2, 9.2 → 9.3)
ESR Upgrades: Extended Support Release to next ESR (e.g., ESR 9.5 → ESR 10.1)
Rolling Upgrade Process Steps
- Shutdown Mattermost on the first node
- Load balancer automatically detects the service is down and stops routing requests to that node
- Upgrade Mattermost on the offline node using your standard upgrade process
- Start Mattermost on the upgraded node
- Verify the node is healthy and receiving traffic again
- Repeat for each remaining node, one at a time
For upgrading individual nodes, follow the Comprehensive Upgrade Guide for your specific installation method.
Key Considerations:
- Only upgrade one node at a time
- Wait for each node to fully start and rejoin the cluster before proceeding to the next
- Verify the load balancer detects the node as healthy before moving to the next node
Database Schema Updates
- Database migrations run automatically on the first node to start with the new version
- Subsequent nodes will detect the migration has completed
- Ensure only one node starts at a time during major version upgrades
Session Management
- User sessions remain valid across the upgrade
- WebSocket connections may briefly disconnect and reconnect
- Users may see brief connection interruptions but won't need to re-login
Load Balancer Requirements
- Health checks must be properly configured to detect service availability
- Health check endpoint:
GET /api/v4/system/ping - Load balancer should automatically remove unhealthy nodes from rotation
Rollback Strategy
If issues are encountered during upgrade, follow your standard rollback procedures for the affected node. The remaining nodes will continue serving traffic.
