Configuring Mattermost for Read-Only Access
Problem
In certain cases, such as compliance requirements, maintenance windows, or incident investigations, administrators may need to prevent new content from being added to a Mattermost instance while still allowing users to view existing channels and messages.
Solution
Mattermost does not have a single “read-only mode” toggle, but you can achieve this by adjusting permissions for all user roles except System Administrators.
Steps to Configure Read-Only Access:
  1. Log in as a System Administrator.
  2. Go to System Console → User Management → Permissions.
  3. Click Edit Scheme for the applicable permission scheme.
  4. For each of the following groups:
    • Guests
    • All Members
    • Channel Admins
    • Channel Administrators
    • Team Administrators
      do the following-
         *Locate the Create Posts permission.
        * Uncheck the box to disable it.
  5. Click Save to apply changes.
Outcome:
  • All non-System Administrator users will have read-only access.
  • System Administrators retain posting permissions.
Was this article helpful?
0 out of 0 found this helpful
0 comments
