How to Enable Slow Query Logging in Elasticsearch
Problem:
You're experiencing search performance issues or suspect slow queries in your Elasticsearch cluster used with Mattermost, and want to enable slow query logging for further debugging.
Solution:
Slow query logging helps identify performance bottlenecks by logging queries and fetch phases that exceed a specified threshold. Follow the appropriate instructions based on your ES environment.
For Self-Hosted ElasticSearch Environments:
Use the following curl command to enable slow query logging for a specific index:
curl -X PUT "<ES_URL>/<index_name>/_settings?pretty" -H 'Content-Type: application/json' -d'
  "index.search.slowlog.threshold.query.warn": "1s",
  "index.search.slowlog.threshold.fetch.warn": "1s"
đŸ”§ Replace <ES_URL> with your ES host and <index_name> with the name of the index you want to monitor (e.g., mattermost-index).
 For AWS OpenSearch users :
AWS provides a simplified way to enable slow query logging via the console. Please check the following doc-  https://aws.amazon.com/blogs/database/viewing-amazon-elasticsearch-service-slow-logs for the same.
Was this article helpful?
0 out of 0 found this helpful
0 comments
