Short Answer
No, Mattermost does not support MariaDB.
Details
Mattermost officially supports PostgreSQL and, for legacy installations, MySQL. However, MariaDB is not a supported database for any Mattermost deployment. While MariaDB and MySQL share a common ancestry, they have diverged significantly over time, especially in features, performance characteristics, and compatibility. As a result, running Mattermost with MariaDB can result in unpredictable behavior, data integrity issues, or compatibility problems.
If You're Currently Using MariaDB
If your Mattermost installation currently uses MariaDB, it is strongly recommended that you migrate your database to MySQL or, preferably, PostgreSQL.
Migrating from MariaDB to MySQL
You can follow the official Oracle guide for migrating from MariaDB to MySQL:
👉 How to Migrate from MariaDB to MySQL 8.0
Future-Proof Your Installation
Given the planned removal of MySQL support in Mattermost v11, it's advisable to migrate directly to PostgreSQL if you're undergoing a database transition. PostgreSQL is the recommended and most extensively tested database for all Mattermost deployments going forward.
Migrating from MySQL to PostgreSQL
To assist with this migration, Mattermost provides a step-by-step guide:
👉 How to Migrate from MySQL to PostgreSQL
| Database | Supported | Notes |
| MariaDB | ❌ No | Not supported; migrate to MySQL or PostgreSQL. |
| MySQL | ⚠️ Limited | Supported for now, but support ends with v11. |
| PostgreSQL | ✅ Yes | Fully supported and recommended for all deployments. |
