Issue: Users may experience call connection failures, receiving the error:
"Call connection failed: We couldn't join the call because the connection timed out."
This occurs in air-gapped Mattermost deployments, particularly when behind a proxy like NGINX, and there are no specific errors in the server logs.
Cause: In air-gapped environments, the Mattermost server may default to using public STUN servers to establish connections. Since the environment is isolated from the internet, the server cannot retrieve a public IP address for the local interface, causing connection timeouts during calls.
Solution: To resolve the issue, configure the iceHostOverride Setting to use the internal IP address of the Mattermost server:
Update Configuration: Modify the Mattermost configuration to specify the internal IP address (the host IP) for the
iceHostOverridesetting to prevent relying on public STUN servers.Example configuration:
ServiceSettings:
IceHostOverride: "your.internal.ip.address"
