Disclaimer: This information is applicable only to Mattermost Professional. We still recommend running PostgreSQL on a dedicated server for optimal performance and reliability.
If you're running Mattermost and PostgreSQL on the same server, you can configure Mattermost to connect to the database over a Unix socket instead of the default TCP/IP connection. This can improve performance and security by avoiding network overhead and limiting exposure.
When to Use a Socket-Based Connection
Mattermost and PostgreSQL are running on the same machine.
You want to reduce overhead from TCP/IP networking.
You prefer not to expose the PostgreSQL port over the network.
Step 1: Find the PostgreSQL Socket Directory
Log in to PostgreSQL with:
sudo -u postgres psql -
Run the following command to identify the socket location:
SHOW unix_socket_directories;This will typically return something like
/var/run/postgresql.
Step 2: Update Mattermost Configuration
Update the SqlSettings.DataSource value in your config.json file or set it via an environment variable.
Example config.json:
"SqlSettings": {
"DriverName": "postgres",
"DataSource": "postgres://mmuser:mostest@/mattermost_test?host=/var/run/postgresql/"
Replace
mmuser,mostest,mattermost_test, and/var/run/postgresql/with your actual PostgreSQL user, password, database name, and socket path. -
Note: The socket path must match the output from the earlier
SHOWcommand.
Step 3: Verify Permissions
Make sure:
The Mattermost server user (e.g.,
mattermost) has read/write permissions to the socket directory. -
The PostgreSQL configuration (
pg_hba.conf) allows connections from Unix sockets.
Example line in pg_hba.conf:
local all all md5
After any changes, reload PostgreSQL:
sudo systemctl reload postgresql
Final Step: Restart Mattermost
Once you've updated the configuration and verified permissions, restart the Mattermost server:
sudo systemctl restart mattermost
Troubleshooting Tips
Check Mattermost logs (
/opt/mattermost/logs/) for database connection errors. -
Verify PostgreSQL is accepting Unix socket connections.
Confirm file permissions on the socket path.
