Applies to: Self-Managed and Mattermost Cloud Customers
Purpose: Improve performance and offload static asset delivery using Amazon CloudFront
Overview
You can improve client performance by hosting Mattermost’s static assets (such as images, JavaScript, and CSS) on Amazon CloudFront. Hosting static assets on a CDN (Content Delivery Network) like CloudFront decreases page load time and reduces load on your Mattermost server.
Requirements
An Amazon Web Services (AWS) account with access to CloudFront.
Access to your Mattermost instance configuration files and server.
Step 1: Create an S3 Bucket
Sign in to your AWS Management Console.
Open the Amazon S3 service.
Create a new S3 bucket (e.g.,
mattermost-static-assets). -
Make the bucket public or configure it for use with a CloudFront OAI (Origin Access Identity).
Step 2: Copy Static Assets
Locate the Mattermost static assets.
These are typically located in:/opt/mattermost/client(self-hosted installs) -
Copy the entire contents of the
clientdirectory to the new S3 bucket.
Example command:
aws s3 sync /opt/mattermost/client s3://mattermost-static-assets
Make sure the files are publicly accessible if not using an OAI.
Step 3: Create a CloudFront Distribution
Open the CloudFront console.
Choose Create Distribution.
Under Origin domain, choose your S3 bucket.
Set Viewer protocol policy to
Redirect HTTP to HTTPS. -
Under Default cache behavior, set:
Cache policy: CachingOptimized
Origin request policy: AllViewerExceptHostHeader
Create the distribution and note the Distribution Domain Name (e.g.,
d123abcd1234.cloudfront.net)
Step 4: Configure Mattermost to Use CloudFront
Update your Mattermost configuration.
Using config.json:
"AssetProxySettings": {
"Enable": true,
"CloudFrontURL": "https://d123abcd1234.cloudfront.net"
Or using System Console:
Go to System Console > Environment > File Storage > Asset Proxy
Enable the asset proxy
Set the CloudFront URL
Step 5: Restart Mattermost
After updating the configuration, restart your Mattermost server for the changes to take effect.
Example:
sudo systemctl restart mattermost
Verification
Open your Mattermost site in a browser.
Open the browser’s developer tools (
F12or right-click > Inspect). -
Go to the Network tab.
Refresh the page and look for assets loading from your CloudFront domain (e.g.,
d123abcd1234.cloudfront.net/static/...).
