Issue: Managing Personal Access Tokens Takes Longer Than Expected
Symptoms:
Users experience prolonged loading times when managing Personal Access Tokens (PATs).
The process appears to run indefinitely without completing.
The issue occurs across all users in Mattermost version 9.11.9.
Cause:
A known performance issue affects the Personal Access Token management functionality in version 9.11.9.
Workaround:
Instead of using the Mattermost UI, use the
mmctlcommand-line tool to list and manage tokens:mmctl token list -
This provides an alternative method to retrieve and manage token information without UI delays.
Solution:
Upgrade to Mattermost 10.3 or Later
The issue has been resolved in Mattermost 10.3+.
Upgrading to 10.5 (the next ESR version) is strongly recommended for performance improvements.
Next Steps:
If affected, use the
mmctlworkaround until an upgrade is planned. -
Upgrade to Mattermost 10.5+ to resolve the issue permanently.
Conclusion
Using the provided workarounds and planning for an upgrade will help mitigate this issue effectively.
