Issue: Unable to Delete Elasticsearch Index Due to Insufficient Permissions
Symptoms:
Users encounter an error when attempting to delete an AWS OpenSearch index from the Mattermost system console.
The error message appears in the Mattermost console and server logs.
The log reports a 403 Forbidden error with a security exception.
Example Error Message:
error [2025-03-28 14:07:34.426 +09:00] Failed to delete Elasticsearch index caller="web/context.go:115" path=/api/v4/elasticsearch/purge_indexes request_id=srs3jdkfxtbwbrtmnhtuszkc8r ip_addr=192.178.191.25 user_id=pqd4xin7yf8y3dxk9uh7iys9xa method=POST err_where=Elasticsearch.PurgeIndexes http_code=500 error="Elasticsearch.PurgeIndexes: Failed to delete Elasticsearch index, elastic: Error 403 (Forbidden): no permissions for [] and User [name=admin, backend_roles=[], requestedTenant=null] [type=security_exception]"
Cause:
The admin user does not have sufficient permissions to delete indexes in OpenSearch.
Some system indices in AWS OpenSearch are protected and cannot be deleted.
Workaround:
Identify protected system indices that cannot be deleted using the following command:
curl -u USER:PASS http://<HOSTNAME>/_cat/indices?v=true -
Any index that starts with a period (.) is considered a system index and cannot be deleted manually.
To prevent Mattermost from attempting to purge these protected indices, configure the
IgnoredPurgeIndexessetting in Mattermost with comma-separated values of system indices:"IgnoredPurgeIndexes": ".opendistro*,.security*"
Next Steps:
Implement the workaround by updating the Elasticsearchsettings.IgnoredPurgeIndexes configuration(config.json) in Mattermost.
If further issues persist, check AWS OpenSearch official documentation for managing permissions and index deletions.
