If you encounter a "Server Not Found" error after changing the Site URL in the System Console, follow these steps to resolve the issue efficiently.
Error screenshot :
Resolution Steps
Correct the Site URL Configuration
Go to System Console > Environment > Web Server.
Ensure the Site URL is correctly set to your desired hostname (e.g.,
http://hostname). -
Confirm the URL includes the correct protocol (
httporhttps).
Adjust Subpath Configuration (If Applicable)
If Mattermost is hosted on a subpath (e.g.,
http://hostname/mattermost), ensure that:-
The Site URL includes the correct subpath.
The web server’s reverse proxy settings are configured to support the subpath.
Clear Browser Cache
Clear your browser cache to ensure the updated Site URL resolves correctly.
Check Firewall Settings
Ensure the firewall allows traffic to and from the configured Site URL.
Verify DNS Configuration
If you recently updated the Site URL, confirm that the DNS record has been correctly configured and DNS propagation has completed.
Review System Logs for Errors
Go to System Console > Logs and review any errors related to the web server or network connectivity.
Additional Assistance
If the issue persists after following these steps, contact Mattermost Support with the following details:
Screenshot of the System Console > Web Server settings.
Screenshot of the "Server Not Found" error.
Details about recent URL changes or firewall adjustments.
By implementing these steps, you can resolve the "Server Not Found" error and restore access to your Mattermost instance.
